[FOSS-GPS] RTKLIB and Master Auxiliary approach
Tomoji TAKASU
ttaka at yk.rim.or.jp
Sat Jun 16 05:16:31 PDT 2012
Dear Fabrizio
> My question is: "When I get Master auxiliary corrections from
> Leica geosystems network, RTKLIB uses Auxiliary stations message?
No.
RTKLIB does not support MAC.
You need to convert MAC corrections to VRS observation
data by yourself.
regards,
Tomoji TAKASU
From: "Fabrizio Toni" <fabrizio.toni at techplanet.it>
Sent: Saturday, June 16, 2012 9:04 PM
To: <foss-gps at lists.osgeo.org>
Subject: [FOSS-GPS] RTKLIB and Master Auxiliary approach
> Hi all,
> I have to conduct an experimentation for railway application to localize
> the trains and eventually distinguish the track in parellal tracks
> scenarios.
> The train could run up to 300 km/h. I'm testing a Denga10 receiver
> (http://www.onetalent-gnss.com/ideas/usb-hw-receivers/denga10) 10 Hz
> output and a low cost antenna Tallysmann TW2410. I'm using RTKNavi and 2
> Gnss permanent station networks (Italpos Leica Geosystems and Netgeo
> Topcon). My question is: "When I get Master auxiliary corrections from
> Leica geosystems network, RTKLIB uses Auxiliary stations message? If so,
> where is locate the source code for the positioning?
> Then I bougth also another Denga10 to set up an RTK system: one Denga10
> as Master base and one as Rover. I'll post the results asap.
> Regards
> Fabrizio Toni*
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
