[FOSS-GPS] RTKLIB and Master Auxiliary approach
Fabrizio Toni
fabrizio.toni at techplanet.it
Sat Jun 16 06:08:13 PDT 2012
So when I use Master auxiliary corrections it's a simple Nearest?
What a pity. Because in high-speed moving vehicle apps I believe MAX is
the best solution.
What about RAIM algoriths to integrate in RTKLIB? In all safety of life
applications is a MUST the integrity risk real-time monitoring.
For example in railway we have very restricted requirements 10^-9 faults
per hours (SIL4 normative
http://en.wikipedia.org/wiki/Safety_Integrity_Level)
I found this interesting paper:
http://eprints.qut.edu.au/31007/1/c31007.pdf
Do you think it could be possible to integrate this or another RAIM
algorithm in RTKLIB?
Regards
Fabrizio Toni*
Il 16/06/2012 14:16, Tomoji TAKASU ha scritto:
> Dear Fabrizio
>> My question is: "When I get Master auxiliary corrections from
>> Leica geosystems network, RTKLIB uses Auxiliary stations message?
> No.
> RTKLIB does not support MAC.
> You need to convert MAC corrections to VRS observation
> data by yourself.
> regards,
> Tomoji TAKASU
> From: "Fabrizio Toni" <fabrizio.toni at techplanet.it>
> Sent: Saturday, June 16, 2012 9:04 PM
> To: <foss-gps at lists.osgeo.org>
> Subject: [FOSS-GPS] RTKLIB and Master Auxiliary approach
>> Hi all,
>> I have to conduct an experimentation for railway application to localize
>> the trains and eventually distinguish the track in parellal tracks
>> scenarios.
>> The train could run up to 300 km/h. I'm testing a Denga10 receiver
>> (http://www.onetalent-gnss.com/ideas/usb-hw-receivers/denga10) 10 Hz
>> output and a low cost antenna Tallysmann TW2410. I'm using RTKNavi and 2
>> Gnss permanent station networks (Italpos Leica Geosystems and Netgeo
>> Topcon). My question is: "When I get Master auxiliary corrections from
>> Leica geosystems network, RTKLIB uses Auxiliary stations message? If so,
>> where is locate the source code for the positioning?
>> Then I bougth also another Denga10 to set up an RTK system: one Denga10
>> as Master base and one as Rover. I'll post the results asap.
>> Regards
>> Fabrizio Toni*
>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>> subscription
>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
> subscription
Fabrizio Toni*
**/TECH PLANET S.r.l./**/
/*/Via A. Zottoli, 32/A
00125 Roma - Italia
*Tel. *(+39) 347-0666704
*e-*/*/mail/*/: info at techplanet.it <mailto:fabrizio.toni at techplanet.it>
*sito web*:http://www.techplanet.it <http://www.techplanet.it/>/
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20120616/dad54273/attachment-0001.html>
Type: image/bmp
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20120616/dad54273/attachment-0001.bin>
More information about the FOSS-GPS
