[FOSS-GPS] RTKLib processing power
Josh Leighton
leighton.josh at gmail.com
Wed Aug 21 17:42:58 PDT 2013
While I can't speak very scientifically, I can report on our experiences
running rtklib on gumstix embedded linux computers. Previous we used a
Gumstix Overo with an ARM cortex-A8 (single core) at 800MHz I believe. We
couldn't reliably do more than 1Hz RTK alongside the other processes we
were running. If I recall correctly, rtknavi was using ~15% cpu at 1Hz.
Now with a Duovero (dual core, arm cortex-A9 at 1GHz) we have no problem
running RTK at 5Hz. Cpu usage is still around 15%.
Hope that's of some help to you.
-Josh
On Wed, Aug 21, 2013 at 8:19 PM, Weber <webersouzacalixto at gmail.com> wrote:
> Hi all,
> Question: How much processing power to get real time RTK corrections from
> RTKLib?
> I'm thinking of using uBlox LEA-6T-0 (5 Hz RAW update) on both basestation
> and rover (a UAV), with RTKNAVI or an adaptation running on the rover so I
> need to choose a onboard computer capable.
> Thanks,
> Weber
> ______________________________**_________________
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/**mailman/listinfo/foss-gps<http://lists.osgeo.org/mailman/listinfo/foss-gps>to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/**FOSS-GPS<http://wiki.osgeo.org/wiki/FOSS-GPS>
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20130821/63672e37/attachment.html>
More information about the FOSS-GPS
