[FOSS-GPS] make NTRIP with RTKLIB
nilocb
colinbouriquet at gmail.com
Sun Aug 25 17:40:21 PDT 2013
ntrip clients and ntrip servers only communicate through a "ntrip caster",
rtklib doesn't provide this functionality.
ntrip server sends data to a ntrip caster which provides it to the ntrip
clients.
Please read the following Web page for a better understanding of how ntrip
works (it will also help you out in case you would like to run your own
ntrip caster)
http://www.profsurv.com/magazine/article.aspx?i=71286
If you use Windows, the Lefebure solution is pretty straightforward, if
you're on Linux the BKG ntrip caster involves compiling and writing your own
Config files, since it's command line only.
Don't worry about RTCM, the ntrip protocol also supports RAW. (I'm using it
with UBX binary and it works very well).
Good luck.
nilocb
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/make-NTRIP-with-RTKLIB-tp7572635p7572722.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
