[FOSS-GPS] RTKLib ready and recommended receiver modules
Danny Miller
dannym at austin.rr.com
Thu Aug 29 11:35:03 PDT 2013
Look at the NV08C:
http://www.nvs-gnss.com/products/receivers/item/2-nv08c-csm.html
It provides RAW output, so it can work with RTKLIB. Someone posted a
modified RTKLIB that accepted CSM's RAW format, I don't know if that's
been included in an official version yet.
Call CSM directly. They do not have a webstore, but just call their
sales. They will sell a couple of units at a surprisingly low price.
Danny
On 8/29/2013 1:25 PM, Hagen.Felix wrote:
> Hi @ all,
> This is my first posting here, I just found this discussion as a result of
> my Google search.
> Please let me explain some details to the actual and upcoming L1 receivers
> which are enabled with carrier phase raw data output to prevent any
> confusion here...
> The u-blox NEO-6P is able to deliver RTKLIB capable raw data with 5 Hz
> update rate (officially and in fact up to 10 Hz) as well as the NEO-6T which
> is the classic timing receiver module.
> Both receiver variants are ROM versions, that means their firmware is not
> upgradeable (in opposite to the newer LEA-6T which contains flash for user
> upgradeable firmware but is unfortunately limited in a very poor update rate
> of less than 2 Hz).
> The NEO-6P is significantly more expansive than the NEO-6T, due to its
> integrated PPP feature (which is quite useless in RTKLIB application
> scenarios).
> But anyway, this PPP goodie (in fact a smart implementation of SBAS together
> with a "carrier smoothing") makes that the NEO-6P is the most bang for the
> buck in autonomous operation modes.
> The successor (NEO-7P) is flash based but nevertheless ready for an official
> update rate of 10 Hz, and is finally ready to use RTCM input instead resp.
> additional to SBAS.
> So far, so good, but unfortunately it seems that there's still no GLONASS
> carrier phase raw data output.
> So if I should try to give a short conclusion and recommendation, I'd like
> say that NVS is still the first choice at the moment, if you want to realize
> any "pure RTKLIB" applications...
> Best regards from Eastern Germany,
> Hagen
> https://www.optimalsystem.de
> View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLib-and-uBlox-7-tp7572711p7572725.html
> Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
