[FOSS-GPS] Moving Baseline mode in RTKLIB
Al yohcnala at gmail.com
Fri May 31 20:09:59 PDT 2013
Hi,  I am trying to measure the distance between two GPS patch antennas
(antennas are fixed relative to each other, but moves together as a single
unit).  I thought the moving baseline mode with RTKLIB is suitable for my
application.  I am using two u_blox LEA6 PPP, one as the rover input and one
as the base station input.  Both uBlox are outputing binary RAW messages.
The serial connections seem okay as I can get position fixes with single
mode.  However when I switch to moving baseline mode, the baseline (E, N and
U-baseline) measurements is all over the place (more than a few meters off
and fluctuating).
Does anyone has experience doing that?  I read here that someone got cm
level accuracy.
Thanks a lot.
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Moving-Baseline-mode-in-RTKLIB-tp7572693.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS mailing list
