[FOSS-GPS] Short moving baseline implementation
Felipe G. Nievinski
fgnievinski at gmail.com
Tue Nov 4 16:31:52 PST 2014
I'd have a third GPS as base station.
Then pick one of the two rover GPS
and process this first as kinematic
w.r.t. the fixed base station. Next,
process the second rover w.r.t. to
the first rover, with RTKLIB's "moving
base station" mode (it's _not_ w.r.t.
to the third, fixed GPS station).
Measure the constant baseline
length between the two rovers
and use that as a constraint
(there's a field for that in RTKLIB).
Make sure the uncertainty of it
is realistic -- tape measurements
won't be better than 1 cm, or 1 in
if the antenna phase centers are
not calibrated. Keep the two rovers
as far apart as possible -- that will
improve the heading solution.
> Message: 1
> Date: Tue, 4 Nov 2014 11:40:45 -0800 (PST)
> From: MarekM <marekm at hot.pl>
> To: foss-gps at lists.osgeo.org
> Subject: [FOSS-GPS] Short moving baseline implementation
> Message-ID: <1415130045046-7573069.post at n2.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> Hello All,
> I wish to use RTK short (approx 2 meters) moving baseline to calculate
> heading angle.
> This is a part of aerial orthophotography camera stabilisation - yaw
> compensation,
> My plan is to use 2 pcs of uBlox LEA-6T modules and STM32F4 microprocessor.
> The questions are: what is minimum set of algoritms/modules to calculate
> angle between two moving antennas? Refrsh rate is 5 Hz - how about
> necessary
> memory and processing power?
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Short-moving-baseline-implementation-tp7573069.html
> Sent from the Open Source GPS-related discussion and support mailing list
> archive at Nabble.com.
> FOSS-GPS mailing list
> FOSS-GPS at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/foss-gps
> End of FOSS-GPS Digest, Vol 70, Issue 3
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20141104/d169bd5f/attachment.html>
More information about the FOSS-GPS
