[FOSS-GPS] Ephemeris storage, how to purge it in RTKLIB and RTKnavi
David Kelley
DavidKelley at iTSware.net
Sat Nov 15 07:38:40 PST 2014
I have basic problem using RTKLIB to ask of the list. That is: where
does RTKLIB (RTKnavi in this case) keep the current broadcast ephemeris
(orbital) data it is using?
The tool will cache any recent ephemeris data it gets a hold of and
reuse that on subsequent runs. So, if you happened be connected to any
stream that sends this data (many NTRIP casters do not - presuming your
local rover will provide it for you) it all works fine. And the default
behavior is to take this data from any of base/rover/corrections streams
(see Options, Misc Tab, "Nav Msgs Selection" drop down). You many not
even notice that a new data stream you are using does not provide the
ephemeris updates until the prior ones time out. And all of this is a
different problem from downloading the data for precise or broadcast
data from a web or FTP site (where the default location is C:\Temp). It
creates a file cache somewhere with this but even with scaning the whole
PC for time stamps I can not find it.
I need to find this file and remove it between every test run, but
frankly I can not find it anywhere. Help.
Regards, David Kelley
More information about the FOSS-GPS
