[FOSS-GPS] Using RTKLib with Novatel OEM device as base
Anton Strydom
agstrydom at gmail.com
Tue Sep 2 11:38:16 PDT 2014
Good evening
Could you send me some sample data as well as the exact model of your
receiver
Regards
Anton
On Tue, Sep 2, 2014 at 8:35 PM, john taflan <taflan.work at gmail.com> wrote:
> Hello,
> I developed a simple script to take the log output, parse it for the hex I
> actually want, and output that back to rtknavi. I have verified that my
> script is sending the bytes properly, and matched up one of the messages
> (RAWWAASFRAME) to the spec in the Novatel manual.
> I've tried both outputting sets of 16 bytes at a time, or holding all the
> bytes until I have a full message and sending that all at once. In both
> cases, I can see RTKlib get the hex properly, but it never parses it as an
> OEM message. At this point I'm really not sure what to do, since I know
> for sure the proper data is sending (I checked every part of the packet
> structure!), but rtklib just isn't recognizing it!
> On Thu, Aug 28, 2014 at 12:41 PM, Anton Strydom <agstrydom at gmail.com>
> wrote:
>> Hi there
>> On certain Novatel receivers you can get the proper data via TCP I am
>> just not sure which ones, The ones I use only have 3 com ports rs232 and
>> bluetooth and I get good data from them
>> Regards
>> On Thu, Aug 28, 2014 at 5:00 PM, jtwork <taflan.work at gmail.com> wrote:
>>> I think I may have discovered the issue... I'm reading the 'log'
>>> information,
>>> which is this odd formatted binary info. It looks like in order to
>>> actually
>>> get the raw binary I have to connect via the serial like you suggested,
>>> however that is impossible in my case since that port is in active use by
>>> someone else.. plus I don't actually have physical access to it!
>>> So, I guess unless there's some way to enable raw output over the network
>>> connection, or I write some weird parser, I won't be using this method...
>>> View this message in context:
>>> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Using-RTKLib-with-Novatel-OEM-device-as-base-tp7572967p7572977.html
>>> Sent from the Open Source GPS-related discussion and support mailing
>>> list archive at Nabble.com.
>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>>> subscription
>>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
>> subscription
> subscription
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140902/c03bdf88/attachment.html>
More information about the FOSS-GPS
