[FOSS-GPS] Using RTKLib with Novatel OEM device as base
jtwork
taflan.work at gmail.com
Wed Sep 3 05:46:55 PDT 2014
Hello,
Below is an example of the one of the messages in the printed data output
from the OEM receiver:
My script simply reads this formatted data, and parses the hex into a string
that is sent to the receiver. For example, it would be something along the
lines of:
I attempted just typing out an entire packet and sending that manually, but
have also confirmed that my script does parse it correctly by viewing the
hex input on the screen you showed me.
My receiver model is the OEMV-3:
http://www.novatel.com/products/gnss-receivers/oem-receiver-boards/oemv-receivers/oemv-3/
I have viewed the firmware quick-reference manual:
http://www.novatel.com/support/info/documents/580
It does indicate that the RAWWAASFRAME is formatted like the log output
shows, so I'm really not certain where I'm going wrong, unless the log data
is for some reason entirely different from the data that RTKlib is looking
for...!
Thanks for your help.
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Using-RTKLib-with-Novatel-OEM-device-as-base-tp7572967p7572984.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
