[FOSS-GPS] RTKLIB: What about PPP-Fixed ?
Tomoji Takasu
ttaka at yk.rim.or.jp
Thu May 7 17:45:58 PDT 2015
Dear Dimitris,
> Could you please tell me if the DCB MGEX products
> (differential code biases, inter-system biases and
> fractional cycle biases) are supported in PPP-AR
> within RTKLIB ?
Currently no.
> Do I just have to use as "Ionosphere Correction"
> the SBAS messages or IONEX TEC files?
I wonder such VTEC products is insufficient to be
used for "PPP-RTK". Usually more accurate STEC is
required. However, there is no standard format for
STEC at this moment.
regards,
Tomoji TAKASU
From: "Dimitris Psychas" <psxdimitris at hotmail.com>
Sent: Thursday, May 7, 2015 9:49 PM
To: "Open Source GPS-related discussion and support"
<foss-gps at lists.osgeo.org>
Subject: Re: [FOSS-GPS] RTKLIB: What about PPP-Fixed ?
> Dear Tomoji,
> thank you for your clarifications. Actually, when I said PPP-RTK I meaned
> the integer ambiguity resolution that takes place in PPP (so according to
> your sayings, the mode PPP-AR is PPP-RTK mode). Could you please tell me
> if the DCB MGEX products (differential code biases, inter-system biases
> and fractional cycle biases) are supported in PPP-AR within RTKLIB ?
> Something else that I would like to know is how can I implement the other
> meaning of RTK in PPP. To put it in other words, how can I have PPP
> solutions that are corrected about ionosphere, etc from a reference
> network ? Do I just have to use as "Ionosphere Correction" the SBAS
> Thank you in advance.
> Best regards,
> Dimitris Psychas
>> From: ttaka at yk.rim.or.jp
>> To: foss-gps at lists.osgeo.org
>> Date: Thu, 7 May 2015 08:45:33 +0900
>> Dear Dimitris,
>> > I am using the package RTKLIB the last months,
>> > in order to evaluate the performance of Precise
>> > Point Positioning (PPP) technique. Does anyone
>> > know what the positioning mode PPP-Fixed in
>> > RTKLIB is ? Is it just for computing residuals?
>> It intends to be used for ZTD estimation or various
>> error analysis (for orbit/clock or multipath).
>> > And one more question, does anyone know
>> > how someone can use the method PPP-RTK
>> > within the package RTKLIB ?
>> If you mean "PPP-RTK" as "PPP-AR", read the last
>> paragraph of the manual E.8.
>> Tomoji TAKASU
>> Sent: Thursday, May 7, 2015 7:08 AM
>> To: <foss-gps at lists.osgeo.org>
>> Subject: [FOSS-GPS] RTKLIB: What about PPP-Fixed ?
>> > Hey to everyone,
>> > I am using the package RTKLIB the last months, in order to evaluate the
>> > performance of Precise Point Positioning (PPP) technique. Does anyone
>> > know
>> > what the positioning mode PPP-Fixed in RTKLIB is ? Is it just for
>> > And one more question, does anyone know how someone can use the method
>> > PPP-RTK within the package RTKLIB ?
>> > Best regards,
>> > Dimitris Psychas
>> > _______________________________________________
>> > This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>> > Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>> > subscription
>> > For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
>> subscription
> subscription
More information about the FOSS-GPS
