[FOSS-GPS] rtrcv base station iput stream issue with ntripclient or tcpclient
Carl Che
cche at utilitytelecomaustralia.com.au
Fri May 8 00:25:12 PDT 2015
G'day,
Has anyone bumped into the following issue using rtcrcv with ntrip caster?
Ntrip Client: always return 401 - unauthorized error.
input base ntripc rtcm3 C 0 0 0 0 HTTP/1.1 401 Unauthorized
I tried BKG BNC and the account works like a charm.
I then tried str2str to retrieve the ntrip stream and it works properly. I then forwarded that stream (as output) into a local TCP port. I tried netcat and the port is working - spelling out RTCM stream. But when I use rtkrcv to source from (as input) the TCP port, it always return port error.
input base tcpcli rtcm3 E 0 0 0 0 port error:
I'm using RTCM 3.1 and Ntrip version 1.
Any ideas?
Best Regards,
Lichang (Carl) Che
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150508/4eaf7840/attachment.html>
More information about the FOSS-GPS
