[FOSS-GPS] rnx2rtkp select GNSS system
Alain Muls
alain.muls at gmail.com
Thu May 9 02:52:27 PDT 2019
Hi All
I often use rnx2rtkp for processing rinex v3 files. I want to compare GPS
to Galileo positioning but without using a configuration file, I cannot
process the Galileo only data files.
I cannot find an option which allows to set the GNSS system to Galileo
only, which through a configuration file can be done. Is there a hidden
option perhaps?
bye/Alain
*Alain Muls*
*Professor*
Department CISS
*Royal Military Academy*
p: +32 2 44 13936
a: Renaissance Avenue 30
B1000 Brussels (Belgium)
w: www.rma.ac.be/ciss/en/ e: alain.muls at rma.ac.be
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20190509/80d270fd/attachment.html>
More information about the FOSS-GPS
