[FOSS-GPS] FOSS-GPS Digest, Vol 113, Issue 2, configuration for galileo
atanu santra
bubunhhh at gmail.com
Thu May 9 21:53:57 PDT 2019
Dear sir,
In windows platform it's very easy to set galileo using 'rtknavi '
application. But please ensure that the receiver is proving raw data on
galileo mode. You can do it using the proprietary software.
Or, you can post process after taking raw data using 'rtkpost'.
In linux platform, you can edit in the configuration file of 'rtkrcv'
application.
You can find in the directory whose path is as follows :
Rtklib master> rtkrcv> configuration file
Best regards,
Atanu Santra
Junior research fellow
GNSS Laboratory
Department of Physics
The University of Burdwan
Golapbag, Burdwan
India
On Fri, 10 May 2019 12:30 am <foss-gps-request at lists.osgeo.org wrote:
> Send FOSS-GPS mailing list submissions to
> foss-gps at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.osgeo.org/mailman/listinfo/foss-gps
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> foss-gps-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of FOSS-GPS digest..."
> Today's Topics:
> 1. rnx2rtkp select GNSS system (Alain Muls)
> Message: 1
> Date: Thu, 9 May 2019 11:52:27 +0200
> From: Alain Muls <alain.muls at gmail.com>
> To: foss-gps at lists.osgeo.org
> Subject: [FOSS-GPS] rnx2rtkp select GNSS system
> Message-ID:
> <CAMKve_pt9KrbPHSTa8KMDCGRV=
> DNgH_Z1OwR6vS4o0n0wPurwg at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hi All
> I often use rnx2rtkp for processing rinex v3 files. I want to compare GPS
> to Galileo positioning but without using a configuration file, I cannot
> process the Galileo only data files.
> I cannot find an option which allows to set the GNSS system to Galileo
> only, which through a configuration file can be done. Is there a hidden
> option perhaps?
> bye/Alain
> *Alain Muls*
> *Professor*
> Department CISS
> *Royal Military Academy*
> p: +32 2 44 13936
> a: Renaissance Avenue 30
> B1000 Brussels (Belgium)
> w: www.rma.ac.be/ciss/en/ e: alain.muls at rma.ac.be
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/foss-gps/attachments/20190509/80d270fd/attachment-0001.html
> Subject: Digest Footer
> FOSS-GPS at lists.osgeo.org
> End of FOSS-GPS Digest, Vol 113, Issue 2
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20190510/b11ebafc/attachment.html>
More information about the FOSS-GPS
