[FOSS-GPS] FOSS-GPS Digest, Vol 113, Issue 2, configuration for galileo
John Ackermann N8UR
jra at febo.com
Fri May 10 07:33:56 PDT 2019
Just a note about rtklib on Linux:
I recently created updated Debian packages based on Jens Reimann's QT
port that include the latest updates (to 2.4.3b32) and also make a
couple of improvements in how the configuration files are handled in a
*nix environment.
I believe that the packages will be available in the Debian "unstable"
repositories soon. They are available now for amd64 and Raspberry Pi at
https://febo.com/pages/gps-nuts/rtklib/debs/ .
John
On 5/10/19 12:53 AM, atanu santra wrote:
> Dear sir,
> In windows platform it's very easy to set galileo using 'rtknavi '
> application. But please ensure that the receiver is proving raw data on
> galileo mode. You can do it using the proprietary software.
> Or, you can post process after taking raw data using 'rtkpost'.
> In linux platform, you can edit in the configuration file of 'rtkrcv'
> application.
> You can find in the directory whose path is as follows :
> Rtklib master> rtkrcv> configuration file
> Best regards,
> Atanu Santra
> Junior research fellow
> GNSS Laboratory
> Department of Physics
> The University of Burdwan
> Golapbag, Burdwan
> India
> On Fri, 10 May 2019 12:30 am <foss-gps-request at lists.osgeo.org
> <mailto:foss-gps-request at lists.osgeo.org> wrote:
> Send FOSS-GPS mailing list submissions to
> foss-gps at lists.osgeo.org <mailto:foss-gps at lists.osgeo.org>
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.osgeo.org/mailman/listinfo/foss-gps
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> foss-gps-owner at lists.osgeo.org
> <mailto:foss-gps-owner at lists.osgeo.org>
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of FOSS-GPS digest..."
> Today's Topics:
> 1. rnx2rtkp select GNSS system (Alain Muls)
> Message: 1
> Date: Thu, 9 May 2019 11:52:27 +0200
> From: Alain Muls <alain.muls at gmail.com <mailto:alain.muls at gmail.com>>
> To: foss-gps at lists.osgeo.org <mailto:foss-gps at lists.osgeo.org>
> Subject: [FOSS-GPS] rnx2rtkp select GNSS system
> Message-ID:
> <CAMKve_pt9KrbPHSTa8KMDCGRV=DNgH_Z1OwR6vS4o0n0wPurwg at mail.gmail.com
> <mailto:DNgH_Z1OwR6vS4o0n0wPurwg at mail.gmail.com>>
> Content-Type: text/plain; charset="utf-8"
> Hi All
> I often use rnx2rtkp for processing rinex v3 files. I want to
> compare GPS
> to Galileo positioning but without using a configuration file, I cannot
> process the Galileo only data files.
> I cannot find an option which allows to set the GNSS system to Galileo
> only, which through a configuration file can be done. Is there a hidden
> option perhaps?
> bye/Alain
> *Alain Muls*
> *Professor*
> Department CISS
> *Royal Military Academy*
> p: +32 2 44 13936
> a: Renaissance Avenue 30
> B1000 Brussels (Belgium)
> w: www.rma.ac.be/ciss/en/ <http://www.rma.ac.be/ciss/en/> e:
> alain.muls at rma.ac.be <mailto:alain.muls at rma.ac.be>
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> <http://lists.osgeo.org/pipermail/foss-gps/attachments/20190509/80d270fd/attachment-0001.html>
> Subject: Digest Footer
> FOSS-GPS at lists.osgeo.org <mailto:FOSS-GPS at lists.osgeo.org>
> End of FOSS-GPS Digest, Vol 113, Issue 2
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit https://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20190510/af4ab4ae/attachment.key>
More information about the FOSS-GPS
