[fusion-users] Jx.Panel Start Maximized/Closed
Nolte, Tim Tim.Nolte at ipcswirelessinc.com
Fri Aug 8 10:31:25 EDT 2008
Here is my code:
	<script type="text/javascript">
		var p1 = null;
		var p2 = null;
		var p3 = null;
		var pm = null;
		window.onload = function() {
			/* make 'thePage' just fill the browser window and resize automagically
			   the user resizes the browser */
			new Jx.Layout('thePage');
			/* the height of toolbars.  For jxskin-border,
			 * its 28 and for jxskin-graphic its 30 */
			var h = 28;
			new Jx.Layout('Main', {bottom: 22, left: 250});
			new Jx.Layout('Statusbar', {height: 22, top: null});
			new Jx.Layout('TaskPane', {bottom: 22, width: 250, left: 0});
			new Jx.Layout('Toolbar', {height: h, bottom: null});
			new Jx.Layout('Splitter', {top: h});
			var splitter = new Jx.Splitter('Splitter', {elements: [$('Map'), $('PanelPane')], containerOptions: [{}, {width: 200}]});
			p1 = new Jx.Panel({label: 'Legend'});
			p1.content.id = 'StaticLegend';
			//p2 = new Jx.Panel({label: 'Layers'});
			//p2.content.id = 'Layers';
			p3 = new Jx.Panel({label: 'Selection'});
			p3.content.id = 'SelectionPanel';
			pm = new Jx.PanelManager('PanelPane', [p1, p3]);
			$('thePage').resize();
			$('thePage').style.visibility = 'visible';
			Fusion.registerForEvent(Fusion.Event.FUSION_INITIALIZED, fusionInitialized);
			Fusion.registerForEvent(Fusion.Event.FUSION_ERROR, fusionError);
			Fusion.initialize();
		function fusionError(eventId, error) {
		    console.log('Fusion Error: \n' + error.toString());
		function fusionInitialized() {
		    var mapWidget = Fusion.getMapById('Map');
		    $('thePage').jxLayout.resize({forceResize:true});
		    $('Toolbar').jxLayout.resize({forceResize:true});
		    //enable pan widget by default
		    mapWidget.activateWidget(Fusion.getWidgetsByType('Pan')[1]);
			pm.maximizePanel(p1); // Maximize the panel at startup
			//var map = Fusion.getWidgetById('Map');
		    //var l = new Jx.Layout($('Toolbar').childNodes[0]);
		    //l.resize();
	</script>
You'll see that in order for me to reference 'pm' & 'p1' within fusionInitialized I need to declare:
		var p1 = null;
		var p2 = null;
		var p3 = null;
		var pm = null;
All outside of window.onload. I'm wondering if there is some other way to address the PanelManager and Panels without decalring the objects this way? The thing that kind of frustrates me is that there is no documentation at all for the jxlib. I found the website and there is nothing there except for the download.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS:    616-706-2438
Fax:    616-554-6484
Web: www.ipcswirelessinc.com
> -----Original Message-----
> From: Tómas Guðmundsson [mailto:tomas at snertill.is]
> Sent: Friday, August 08, 2008 10:12 AM
> To: Nolte, Tim; fusion-users at lists.osgeo.org
> Subject: RE: [fusion-users] Jx.Panel Start Maximized/Closed
> Hi
> I'm sorry Tim, but I'm not sure what you're trying to
> accomplish. I can only ask you to rephrase your problem
> and take a look at this old email from this mailing list:
> http://lists.osgeo.org/pipermail/fusion-users/2008-July/000176.html
> Hope that explains some problems I solved regarding panels
> and resizing.
> Regards,
> Tómas.
> From: Nolte, Tim [mailto:Tim.Nolte at ipcswirelessinc.com]
> Sent: 8. ágúst 2008 13:42
> To: Tómas Guðmundsson; fusion-users at lists.osgeo.org
> I was aware of the maximizePanel function of the
> PanelManager. The problem I can't figure out is how to
> address the PanelManager & Panel I want to maximize inside
> the fusionInitialized function. The PanelManager & Panels are
> getting created in the onload function and as a result it
> seems that those objects are only accessibly within that
> scope. If I create the empty JS objects in the public scope
> first then I am able to access the PanelManager & Panels
> inside the fusionInitialized function but I'm not sure this
> is the proper way of accomplishing this. I've tried looking
> through the DOM (via firebug) and looked through both the
> jx_combined.js & fusion-combined.js to figure out if there is
> some what of addressing these objects. I have to admit that
> I'm no expert in JS but I do have a fairly good handle on things.
> BTW...having that one panel maximized on startup is exactly
> what I'm trying to accomplish. Thanks.
> - Tim
> iPCS Wireless, Inc.
> Kentwood, MI 49512
> PCS:    616-706-2438
> Fax:    616-554-6484
> > Sent: Friday, August 08, 2008 5:08 AM
> > Hi tim,
> > Not sure if this is what you're looking for but in index.html
> > under the
> > templates folder for the template you are using there is a
> > function called
> > fusionInitialized. In there you can ask the panelman,
> > (manager of panels)
> > to maximize a single panel for you.
> > var fusionInitialized = function() {
> >     $('AppContainer').resize({forceResize: true});
> >     panelman.maximizePanel(panel1); // Maximize the panel
> at startup.
> > However, I do not know how to programmatically resize the
> > panels so that
> > one is x sized, other is y sized and all others are closed
> > for example.
> > (If that is what you're looking for).
> > Regards,
> > Tómas
> > From: fusion-users-bounces at lists.osgeo.org
> > [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of
> Nolte, Tim
> > Sent: 7. ágúst 2008 16:37
> > To: fusion-users at lists.osgeo.org
> > Subject: [fusion-users] Jx.Panel Start Maximized/Closed
> > I've got two widgets in a panel bar. I'd like one to be default
> > maximized and the other default closed, when first launching
> > the Fusion
> > application. I've tried looking through the JX JavaScript
> > file to get a
> > handle on how the Panel are constructed. I see that there are
> > some items
> > in there to maximize, and even found a 'state' option for panels.
> > However, it seems that the 'state' (open/closed) option isn't
> > implemented yet. Anyone have any suggestions on this? Thanks.
> > - Tim
> > iPCS Wireless, Inc.
> > Kentwood, MI 49512
> > PCS:    616-706-2438
> > Fax:    616-554-6484
> > fusion-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users mailing list
