[fusion-users] Jx.Panel Start Maximized/Closed
Tómas Guðmundsson
tomas at snertill.is
Fri Aug 8 10:11:47 EDT 2008
Hi
I'm sorry Tim, but I'm not sure what you're trying to accomplish. I can only ask you to rephrase your problem
and take a look at this old email from this mailing list: http://lists.osgeo.org/pipermail/fusion-users/2008-July/000176.html
Hope that explains some problems I solved regarding panels and resizing.
Regards,
Tómas.
-----Original Message-----
From: Nolte, Tim [mailto:Tim.Nolte at ipcswirelessinc.com]
Sent: 8. ágúst 2008 13:42
To: Tómas Guðmundsson; fusion-users at lists.osgeo.org
Subject: RE: [fusion-users] Jx.Panel Start Maximized/Closed
I was aware of the maximizePanel function of the PanelManager. The problem I can't figure out is how to address the PanelManager & Panel I want to maximize inside the fusionInitialized function. The PanelManager & Panels are getting created in the onload function and as a result it seems that those objects are only accessibly within that scope. If I create the empty JS objects in the public scope first then I am able to access the PanelManager & Panels inside the fusionInitialized function but I'm not sure this is the proper way of accomplishing this. I've tried looking through the DOM (via firebug) and looked through both the jx_combined.js & fusion-combined.js to figure out if there is some what of addressing these objects. I have to admit that I'm no expert in JS but I do have a fairly good handle on things.
BTW...having that one panel maximized on startup is exactly what I'm trying to accomplish. Thanks.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
> From: Tómas Guðmundsson [mailto:tomas at snertill.is]
> Sent: Friday, August 08, 2008 5:08 AM
> To: Nolte, Tim; fusion-users at lists.osgeo.org
> Hi tim,
> Not sure if this is what you're looking for but in index.html
> under the
> templates folder for the template you are using there is a
> function called
> fusionInitialized. In there you can ask the panelman,
> (manager of panels)
> to maximize a single panel for you.
> var fusionInitialized = function() {
> $('AppContainer').resize({forceResize: true});
> panelman.maximizePanel(panel1); // Maximize the panel at startup.
> However, I do not know how to programmatically resize the
> panels so that
> one is x sized, other is y sized and all others are closed
> for example.
> (If that is what you're looking for).
> Regards,
> Tómas
> From: fusion-users-bounces at lists.osgeo.org
> [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Nolte, Tim
> Sent: 7. ágúst 2008 16:37
> To: fusion-users at lists.osgeo.org
> Subject: [fusion-users] Jx.Panel Start Maximized/Closed
> I've got two widgets in a panel bar. I'd like one to be default
> maximized and the other default closed, when first launching
> the Fusion
> application. I've tried looking through the JX JavaScript
> file to get a
> handle on how the Panel are constructed. I see that there are
> some items
> in there to maximize, and even found a 'state' option for panels.
> However, it seems that the 'state' (open/closed) option isn't
> implemented yet. Anyone have any suggestions on this? Thanks.
> - Tim
> iPCS Wireless, Inc.
> Kentwood, MI 49512
> PCS: 616-706-2438
> Fax: 616-554-6484
> fusion-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users
