[fusion-users] ApplicationDefinition.xml and the browser cache
Paul Spencer
pspencer at dmsolutions.ca
Tue Aug 19 08:45:49 EDT 2008
Stuart,
I think some browsers or web servers complain if you add query string
parameters to a GET request for static content.
There is supposed to be a way to modify the request headers on the
client side to avoid caching, I'm pretty sure that hasn't been done in
the fusion code yet.
Obviously for production use, you want caching enabled so typically
for development/debugging we use the web development extension for
FireFox which provides an option to disable the cache and a shortcut
to clear the cache. For IE, there is a similar developer toolbar
which allows you to clear the cache quickly, and another thing called
IE Tester which allows you to run different versions of IE in tabs
that has a Refresh Complete (no cache) option.
Cheers
Paul
On 19-Aug-08, at 4:27 AM, gingerbbm wrote:
> Any tips on definitively emptying the browser cache between edits of
> ApplicationDefinition.xml? Both Firefox and IE resiliently hold on
> to old
> versions and it's very irritating. Does anyone have a solution?
> I tried the following change in fusion.js but although initially the
> results
> were promising it appears to breaking something else (which I've not
> yet had
> time to investigate):
> this.applicationDefinitionURL = 'ApplicationDefinition.xml?rand=' +
> parseInt(Math.random()*99999999);
> Thanks
> Stuart
> View this message in context: http://www.nabble.com/ApplicationDefinition.xml-and-the-browser-cache-tp19046219p19046219.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://www.dmsolutions.ca/
More information about the fusion-users
