[fusion-users] Fusion for MapServer in Windows
Paul Spencer pagameba at gmail.com
Wed Jul 21 08:59:29 EDT 2010
what you have provided is a normal file that gets loaded by Fusion for handling translations, it is the set of english translations.  The error is probably happening somewhere else, can you look for some more possible error messages to identify the problem?  Also the php error log may help.
Cheers
Paul
On 2010-07-21, at 6:19 AM, Edi.Karadumi wrote:
> I have made an application with mapserver and c#, but now im moving in
> Fusion. I am having troubles with the example in the fusion tutorial. I have
> extracted the fusion files in C:\ms4w\apps and the index.html and
> applicationdefinition in the apache\htdocs\demo folder. when i run the
> http://localhost/demo the widgets show but i cant see the map. i can see a
> worning in my chrome browser with inspect element and it says:
> Fusion.Strings.en = {
> 'scriptFailed': 'failed to load script: ${script}',
> 'configParseError': 'Error parsing fusion configuration file, initialization
> aborted',
> 'configLoadError': 'Error loading fusion configuration file, initialization
> aborted',
> 'ajaxError': 'Exception occurred in AJAX callback.\nMessage:
> ${exception}\nLocation: ${filename} (${line})\nResponse: ${response}',
> 'importFailed': 'failed to import stylesheet: ${url}',
> 'registerEventError': 'Error registering eventID, invalid (empty) eventID.',
> 'appDefLoadFailed': 'failed to load: ${script}',
> 'appDefParseError': 'failed to parse ApplicationDefinition',
> 'widgetSetParseError': 'failed to parse the WidgetSet',
> 'fusionError': 'Fusion Error: ${type}\n${message}',
> 'nullExtents': 'Map.setExtents called with null extents',
> 'mapLoadError': 'Failed to load requested map:\n${error}',
> 'setLayersError': "setLayers failure: ${error}",
> 'printTitle': 'Printable Page ',
> 'noSelection': 'No Selection',
> 'selectionInfo': '${features} features selected on ${layers} layers',
> 'attribute': 'Attribute',
> 'value': 'Value',
> 'taskHome': 'return to the task pane home',
> 'prevTask': 'go to previous task executed',
> 'nextTask': 'go to next task executed',
> 'taskList': 'Task List',
> 'taskPane': 'Task Pane',
> 'imperial': 'Imperial',
> 'metric': 'Metric',
> 'deg': 'Degrees',
> 'refresh': 'Refresh',
> 'expandAll': 'Expand All',
> 'expand': 'Expand',
> 'collapseAll': 'Collapse All',
> 'collapse': 'Collapse',
> 'defaultMapTitle': 'Map',
> 'legendTitle': 'Legend',
> 'selectionPanelTitle': 'Selection',
> 'ovmapTitle': 'Overview Map',
> 'ovmapTitleShort': 'Overview',
> 'taskPaneTitle': 'Tasks',
> 'segment': 'Segment ${seg}',
> 'calculating': 'calculating ...',
> 'panWest': 'Pan West',
> 'panEast': 'Pan East',
> 'panSouth': 'Pan South',
> 'panNorth': 'Pan North',
> 'zoomOut': 'Zoom Out',
> 'zoomIn': 'Zoom In',
> 'end': ''
> can anyone help me, i cant find any answer for this error
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fusion-for-MapServer-in-Windows-tp5320494p5320494.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users mailing list
