[Gdal-dev] Need help compiling on Windows with Dev-C++ and MinGW
Thom DeCarlo t.r.decarlo at larc.nasa.gov
Fri Sep 24 14:13:22 EDT 2004
Martin,
Yeah, that will work just fine... if you have Microsoft Visual Studio. The
problem I was addressing here was that I don't have that compiler.
Fortunately, Cygwin's implementation of GNU C++ works just fine for GDAL. I
am having problems, though, getting the OpenSceneGraph and requisite
libraries to compile. But, I'll address those problems on that mailing list.
Thom
> -----Original Message-----
> From: Chapman, Martin
> Sent: Friday, September 24, 2004 11:41 AM
> To: Thom DeCarlo; GDAL developers
> Subject: RE: [Gdal-dev] Need help compiling on Windows with Dev-C++ and
> MinGW
> Tom,
> If you follow the directions at
> http://www.remotesensing.org:16080/gdal/gdal_building.html under
> "Building on Windows" verbatum it will work perfectly.  You may need to
> modify the nmake.opt file to set your gdal path correctly, but it will
> work.  It's a command line build but I've had great success with it.
> I'm using VC++ .Net 2003.
> Martin
> From: Thom DeCarlo
> Sent: Friday, September 24, 2004 8:42 AM
> To: 'GDAL developers'
> MinGW
> Well, I wasn't able to compile with MinGW. However I was able to compile
> after installing the Cygwin environment. Now to figure out how to
> compile OpenSceneGraph with that...
> Thom
> > From: Thom DeCarlo
> > Sent: Wednesday, September 22, 2004 3:44 PM
> > Subject: [Gdal-dev] Need help compiling on Windows with Dev-C++ and
> > MinGW
> > Well, the subject says it all. I need to build gdal on a Win2K machine
> > that does not have the MS compilers. I am a complete newbie when it
> > comes to Dev-C++ and MinGW, but I have successfully installed the
> > software.
> > Can anyone provide any help getting gdal to compile? Or maybe just
> > point me at another info source?
> > Thanks,
> > Thom
