[Gdal-dev] Next Generation Language Binding News
Howard Butler hobu at iastate.edu
Fri Aug 5 18:10:06 EDT 2005
Kevin Ruland and myself (well, Kevin mostly) have been working on the next
generation bindings for GDAL.  These new bindings take advantage of new
features in SWIG 1.3.25.  Most importantly, this development provides the
architecture for supporting more languages than the current Python and VB
bindings.  This post will describe the work that has been going on, what is
yet to be done, and how we need your help.
Work that has gone on
Current Python bindings for GDAL are generated with SWIG 1.1, with a lot of
hand rolling of code by Frank.  They work great, but the development is not
sustainable when you start factoring in the desire to have more than Python
be supported.  In addition, migrating these bindings from 1.1 to 1.3 SWIG
is difficult because Frank had to do a lot of swig voodoo to get what he
needed.
In February, Kevin and myself started working on new SWIG definition files,
in a similar fashion to MapScript, that provide a fully backward-compatible
Python interface and provide the architecture to support more language
bindings in a more automated way.  The ng Python bindings were in a
reasonable state just before the OSGIS conference and throughout the spring
I worked on C# bindings.
In addition, Kevin, heavyweight that he his, tore into SWIG itself to make
it support PHP better and bring SWIG PHP support to the same level as many
of the other languages in SWIG specifically for the development of PHP GDAL
wrappers.  These updates are expected to be available in an upcoming SWIG
release...
Where we're at now
So, to recap where we're at, ng Python bindings are backward compatible
(however lightly tested) with existing Python bindings, C# has bindings
that are about 90% of the way there, and PHP bindings are on the
horizon.  Now I'm going to explain what has yet to be done.
1.  SWIG is a fantastic, if arcane, tool that allows you to auto-generate
code to bind C/C++ to one of its supported langauges.  There are a few
gotchas with SWIG though.  First, not all of the concepts in every language
transfers easily to other languages.  For example, things like default
arguments, common in Python don't translate to Java.  Module-level
variables, common in C/C++, Python and others, don't work in C#.  Second,
the types in one language (C/C++, for example) cannot be automagically
coerced into the types of another language (list of strings in C#, for
example).  SWIG has a system called typemaps that a programmer must use to
provide definitions for how SWIG is to make these kinds of coercions.  So,
while SWIG gets you through the boring 90% of generating the bindings,
there's still a really messy 10% that has to be done.
2.  ng Python bindings have almost all of the their typemaps done, past
most of the gdalautotest suite of tests, and seem to be working pretty
well.  I have used these fairly extensively.  It is important that they are
widely tested before we attempt to replace the current Python bindings with
these, however.
3.  ng C# bindings are 90% of the way there.  The build environment exists,
C# and C/C++ dlls are created as expected, and you can import everything
into Visual Studio .NET and use them some.  It's that last 10% that is the
killer though.  There are *no* typemaps beyond the stock SWIG ones.  This
means you can't return a list of GeoTransform variables... instead you just
get back a pointer to it.
4.  Some PHP typemaps exist, and I can let Kevin explain things further,
but an updated SWIG with Kevin's improvements isn't available yet, so these
are a ways off.
5.  Charlie Savage has been playing around with working up Ruby
bindings.  I'll let him comment on how much progress has been made.
6.  No Java, Perl or TCL bindings have been attempted.  Java users could
use the C# bindings as a template -- adding in typemaps  specific to Java
where needed.  Perl and TCL users might use the Python bindings as a template.
How we need your help
We need developers who have expertise in their pet language's C/C++
API.  For C#, this is the PINVOKE mechanism.  For Python, it is the Python
C API.  For Java, it is JNI.  And so on.  There is some typemap code for
individual languages in MapScript that might be useful as a guide.  Without
the typemaps, your language will be a second class citizen ... you'll have
primitive bindings, but you won't be able to do everything you want.  This
situation is still better than where you might have been before the ng
development -- hand-rolling bindings entirely by yourself.
To reiterate, if you are a Python GDAL user, please test the ng bindings in
the upcoming 1.3 beta.  They are located under swig/python.  C# users might
grab a copy of SWIG 1.3.25 from Sourceforge and build up C# bindings with
the makefile.vc that exists in swig/csharp.  Anyone else who has a language
not mentioned should check out the stuff in the swig directory and see how
they might make SWIG generate what they need.
Howard
