[Gdal-dev] RE: GDAL netcdf convention CF support
Simon.Cox at csiro.au
Mon Aug 22 23:07:04 EDT 2005
Note that the addition of temporal operators to the Filter-encoding
specification has been proposed within OWS3.
A provisional schema is in use in the testbed and is available from the
initiative SubVersion code repository (currently only available to
project participants and observers).
Simon
> -----Original Message-----
> From: owner-galeon at unidata.ucar.edu
> [mailto:owner-galeon at unidata.ucar.edu] On Behalf Of Ron Lake
> Sent: Monday, 22 August 2005 2:14 PM
> To: warmerdam at pobox.com; Gerry Creager N5JXS
> Cc: gdal-dev at lists.maptools.org; galeon at unidata.ucar.edu
> Subject: RE: GDAL netcdf convention CF support
> Hi,
> This would seem a natural extension to the OGC WFS
> specification. Note that GML incorporates (under features):
> Coverages and support for time (as well as temporal reference
> systems) and dynamic features. Extending MapServer to being
> a WFS that supports these features would be a good place to
> start. You can likely go some distance with the existing WFS
> spec. What is needed of course is support for 1) temporal
> data types (MapServer extension) 2) temporal operators (WFS
> extension) ..
> Cheers
> Ron
> [mailto:owner-galeon at unidata.ucar.edu] On Behalf Of Frank Warmerdam
> Sent: August 21, 2005 1:41 PM
> To: Gerry Creager N5JXS
> Subject: Re: GDAL netcdf convention CF support
> On 8/21/05, Gerry Creager N5JXS <gerry.creager at tamu.edu> wrote:
> > Frank, et al,
> > I think we need to be thinking either about making GDAL more
> > interested in 3D/4D datasets, as that's coming whether
> we're ready or
> > not... in fact, for me, it's already here.. and then see if
> we need to
> > consider forking or augmenting Mapserver to accommodate it.
> > I see a lot of conceptual problems for Mapserver, and, for that
> > matter, a LOT of GIS packages in incorporating 3D/4D data, and
> > presenting it properly. This has been an issue for GIS
> practitioners
> since just about
> > forever: They think in 2 dimensions and can't, as a group,
> > appreciate the need for either vertical, or time. They
> represent time
> > series data as a series of static images.
> > I see, in Mapserver, a potential interface. It's
> open-source and thus
> > maleable for applications like this. It won't be simple or
> > straightforward, and in the end, Mapserver might serve solely as an
> > example framework for a new 3D/4D display/dissemination tool, but it
> > *is* a starting point.
> > I'm kinda thinking about a melding of Mapserver and IDV, in
> th elong
> > run.
> Gerry,
> The idea of extending mapserver and GDAL to better support
> 3D/4D datasets has been brought up a few time, and I have
> generally been quite ... conservative ... in response. I am
> concerned about substantial complication and turmoil in the
> interfaces of both.
> My personal opinion is that in the shorter term it would make
> more sense to have a distinct multi-dimensional WCS server
> implemented that might derive some code from MapServer, but
> that would otherwise be quite distinct. It would ignore all
> the vector and "portral" related support in MapServer in
> favor of focusing on serving n-dimensional raster data via WCS.
> There could be an n-dimensional equivelent to GDAL as well,
> that might even include a GDAL plugin for 2D datasets, but
> that would have it's own interfaces that are more organized
> to n-dimensional data. Perhaps it could even be closely
> related to one of the existing n-dimensional file format
> libraries like netcdf or HDF (my understanding is that the
> next general netcdf is based on HDF5).
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial
> Programmer for Rent
