[Gdal-dev] Problem with gdalwarp on Win XP
Frank Warmerdam fwarmerdam at gmail.com
Mon Mar 21 16:37:34 EST 2005
On Mon, 21 Mar 2005 16:31:30 -0500, naumov at buffalo.edu
<naumov at buffalo.edu> wrote:
> but I get a popup saying "gdalwarp.exe has encountered a problem and
> needs to close. ...".
Aleksey,
It would likely be best for you to submit a bug report via bugzilla with
a pointer to a file I can use to reproduce the problem and the exact
commandline arguments you used.    Nothing leaps to mind as likely
to be at fault.
Best regards,
