[Gdal-dev] Re: ECW JPEG 2000 Source SDK v3.3 (RC)
Garrett Potts
potts at cfl.rr.com
Thu Nov 10 12:05:24 EST 2005
Hello All:
Thank you for the responses. It makes me a little more confident
that its not just my machine.
I am using the ./configure also. did a make install of the ecwjp2
libraries. I then did a ./configure --with-ecw=yes in gdal and it
built all the way as well. I wonder if it's the static libecwj2 that
is causing an issue. I don't see why. But I have had problems in
the past when a library was static versus dynamic.
Take care
Garrett
On Nov 10, 2005, at 11:52 AM, William Kyngesburye wrote:
> Not a core dump, but I'm getting a trace trap thing:
> Sumomo:~ williamk$ gdal_translate -of JP2ECW s24141.tif testold.jp2
> Input file size is 4357, 8343
> 0.Trace/BPT trap
> I don't think GDAL is having a problem reading the file (saved from
> Photoshop) - I used the same file to time test the JasPer JP2
> output, so it must be ECW. I have ECW (3.3RC1) built the old way
> thru configure, with the multiple libraries. ER left out the qmake-
> generated makefile for the dynamic libecwj2 in this release, so I
> couldn't try that (maybe that's one of those 'other queries' Tom
> Lynch mentioned).
> Mac OS 10.4.3 on a PowerBook G4.
> And I just added ECW to my GIS Libs package... :(
> On Nov 10, 2005, at 9:47 AM, Garrett Potts wrote:
>> Hello All:
>> I meant for this to also go to the GDAL list. I keep experiencing
>> core dumps when enabling the ecw driver on the MAC. I was
>> wondering if anyone else is having the same problems?
>> Take care
>> Garrett
>> Begin forwarded message:
>>> From: Garrett Potts <potts at cfl.rr.com>
>>> Date: November 9, 2005 7:24:14 AM EST
>>> To: Tom Lynch <tflynch at gmail.com>
>>> Cc: gdal-dev <gdal-dev at remotesensing.org>
>>> Subject: Re: [Gdal-dev] Re: ECW JPEG 2000 Source SDK v3.3 (RC)
>>> Hello Tom:
>>> No problem. I'll send anything your way if I find anything.
>>> Also, have you guys been seeing core dumps when using on the
>>> MACOSX through GDAL? Has anyone on the list have MACS they are
>>> running with the ecw/jp2 support built in?
>>> Take care all
>>> Garrett
>>> On Nov 8, 2005, at 7:35 PM, Tom Lynch wrote:
>>>> On 10/26/05, Garrett Potts <potts at cfl.rr.com> wrote:
>>>>> On my MAC I had to set int tempSize = sizeof(struct sockaddr);
>>>>> to
>>>>> socklen_temt pSize = sizeof(struct sockaddr);
>>>> Thanks for this modification, Garrett. I'll see it gets folded
>>>> into
>>>> the source over here.
>>>> I'm also looking at some of the other queries that we've seen since
>>>> RC1 went out.
>>>> Regards,
>>>> Tom Lynch
>>>> Development, ER Mapper
>>>> Phone: +61 8 93882900
>>>> Fax: +61 8 93882901
>>>> Email: tom.lynch at ermapper.com
>>>> Web: http://www.ermapper.com
>>>> Forums: http://forum.ermapper.com
>> Gdal-dev mailing list
>> Gdal-dev at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/gdal-dev
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
