[Gdal-dev] DGN format and projection support
Jeff L. nf10 at hotmail.com
Tue Oct 18 12:59:22 EDT 2005
I downloaded GDAL source code and tried out the DGN as an output format but
it seems that the DGN ogr driver does not support coordinate system. Is this
correct ? if yes, I'm wondering if there is any work around this to generate
DGN with coordinate system ? (scenario: convert mapInfo files to dgn)
Thanks
Jeff
