[Gdal-dev] DGN format and projection support
Tue Oct 18 13:46:47 EDT 2005
On 10/18/05, Jeff L. <nf10 at hotmail.com> wrote:
> Hi,
> I downloaded GDAL source code and tried out the DGN as an output format but
> it seems that the DGN ogr driver does not support coordinate system. Is this
> correct ? if yes, I'm wondering if there is any work around this to generate
> DGN with coordinate system ? (scenario: convert mapInfo files to dgn)
Jeff,
Your analysis is correct.  I don't know how Microstation stores
coordinate system information in DGNs, and I suspect that in
most geographic maps they don't even bother.
Best regards,
