[Gdal-dev] Can't configure GDAL for FreeBSD 5.5
vic at telerem.ru
vic at telerem.ru
Sat Dec 16 19:02:01 EST 2006
Hello Mateusz Loskot,
Sunday, December 17, 2006, 1:26:09 AM, you wrote:
ML> vic at telerem.ru wrote:
>> But nothing happens. What I nave to comment in configure to switch off
>> test PostgreSQL?
ML> A dirty fix is to remove PostgreSQL tests completely:
ML> 1. Open configure.in (not configure) and delete lines 240:294.
ML> 2. Run ./autogen.sh to regenerate configure script from configure.in
ML> 3. Run ./configure and see if it works
ML> NOTE: edit ./configure.in, but not ./configure
Thank you
But autogen.sh doesn't work on my computer:
aip2# ./autogen.sh
+ aclocal -I ./m4
aclocal: not found
+ autoheader
autoheader: not found
+ autoconf
autoconf: not found
But I think error in other place, where created next string
------------------------------- start code
aip2# grep ">&6\B" configure
echo "${ECHO_T}no" >&6LIBZ
echo "${ECHO_T}setting DODS root directory to $with_sqlite" >&6_
------------------------------- end code
I try to find there in 'configure.in', but can't :(
