Fwd: [Gdal-dev] ECW JPEG 2000 SDK 3.3 RC2 now online
Howard Butler
hobu at iastate.edu
Mon Feb 20 12:26:42 EST 2006
An out-of-the-box ./configure and make on OSX gcc 4.0.1 died in a
flurry of errors for me. RC1 would not link properly.
Is there any possibility of an ECW-dev maillist and a public CVS so
we can track things?
Another data point, although I don't know if it is useful, is that
Python needs to do some magic to compile on OSX because of its borken
semaphores. Chasing down HAVE_BROKEN_POSIX_SEMAPHORES in the Python
source code might give some
ideas.
<http://blogs.nuxeo.com/sections/blogs/florent_guillaume/2005_05_21_compiling_python_2_3_5>
Howard
At 09:54 AM 2/9/2006, Tom Lynch wrote:
>On 2/9/06, William Kyngesburye <woklist at kyngchaos.com> wrote:
> Rats. Still not working on Mac OS X. Trace/BPT Trap error. This is
> on 10.4/GCC 4 and 10.3/GCC 3.3 (at least I finally got it to build on
> 10.3). Built with the Gnu configure method, static libecwj2, dynamic
> libNCS* trio. I even tried the examples this time, thinking GDAL
> might be causing problems.
> Was this one of the major problems you mentioned? Or are you still
> working on the Mac OS X issue? Do you have any idea yet what the
> cause is?
>William,
>Sounds like it. I have seen that error during compressions on
>MacOS X. MacOS X has some known oddities in its POSIX threads
>support, my current theory is that is breaking some assumptions made
>by our portable threading code. I have already had to do a couple of
>evil things in there to make decompression support work correctly.
>The Qmake files included in the build are expected to be deprecated in
>future releases, but it's reasonably certain building with them
>wouldn't fix this issue in any case.
>Unfortunately, I will be offline for most of next week, and at this
>point I can't give you an ETA on a fix. It is on my agenda, because
>most of the serious issues that have occurred with libecwj2 group
>around the portable threading code. It may be in need of more drastic
>changes than the hacks that have occurred up to this point :-)
>If you are interested in investigating and possibly fixing the problem
>yourself, check out the files
>$LIBECWJ2/Source/C/NCSUtil/thread.c
>$LIBECWJ2/Source/C/NCSUtil/mutex.c
>My first thought was that a reimplementation for MacOS X in terms of
>Carbon multiprocessing services or mach threads might be in order.
>Tom Lynch
>Development, ER Mapper
>Phone: +61 8 93882900
>Fax: +61 8 93882901
>Email: tom.lynch at ermapper.com
>Web: http://www.ermapper.com
>Forums: http://forum.ermapper.com
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at lists.maptools.org
>http://lists.maptools.org/mailman/listinfo/gdal-dev
