[Gdal-dev] MODIS Equal Area Sinusoidal projection
Tim Beckmann
tbeckman at usgs.gov
Fri Jun 2 10:29:19 EDT 2006
Or try the MODIS reprojection tool available at
http://edcdaac.usgs.gov/landdaac/tools/modis/index.asp
gdal-dev-bounces at lists.maptools.org wrote on 06/02/2006 07:12:10 AM:
> Hi Jose
> > -----Message d'origine-----
> > De : gdal-dev-bounces at lists.maptools.org
> > [mailto: gdal-dev-bounces at lists.maptools.org] De la part de
> > Jose Luis Gomez Dans
> > Envoyé : vendredi 2 juin 2006 12:32
> > À : gdal-dev at lists.maptools.org
> > Objet : [Gdal-dev] MODIS Equal Area Sinusoidal projection
> > Hi!
> > The MODIS HDF files for level 4 (and up) products are given
> > using the "Equal Area Sinusoidal Projection". I have tried to
> > select one dataset, and export it to a GeoTIFF file using
> > GDAL, but the projection information does not seem to
> > work.The output GeoTIFF file does have the right metadata,
> > thre resulting raster is not properly reprojected. I have
> > also tried to set the source projection with "+proj=sinu",
> > but this does not seem to produce a good result.
> > What I want to do is to extract one dataset from a MODIS HDF
> > file, reproject it to UTM and then cut an area of interest.
> > However, without dealing with the projection issue first.
> > Any pointers would be very appreciated!
> You should try HEG Tool http://newsroom.gsfc.nasa.
> gov/sdptoolkit/HEG/HEGHome.html.
> This tool is made for EOS datasets including MODIS. There is a UTM
> option for repojection and subsetting. You can also use it in batch
> mode. But I do not think it uses GDAL.
> Regards,
> Guillaume HUBY._______________________________________________
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060602/f0a818c4/attachment.html
