[Gdal-dev] GDAL + Link Error
salah jubeh
s_jubeh at yahoo.com
Thu Mar 9 10:58:10 EST 2006
Hello
I couldn't build gdal with the new release , i have solve the link error , but after that i get many error "unresolved external ...", also i compared the structure of the two versions the are much different.
I used older version which is HDF41r5 , the code compiled but you have to copy 4 lib library to gdal home which are hd415.lib, hm415.lib, hd415m.lib, hm415m.lib
Frank Warmerdam <warmerdam at pobox.com> wrote: salah jubeh wrote:
> I have edited gdal nmake.opt to specify the hdf location folder , i
> specefy it like this
> # Uncomment the following and update to enable NCSA HDF Release 4 support.
> HDF4_DIR = C:\projects\42r1-win\release
> HDF4_LIB = /LIBPATH:$(HDF4_DIR)\lib Ws2_32.lib
> why i get the link error
> LINK : fatal error LNK1104: cannot open file 'HD421m.lib'
> I checked this file and it is exist in
> C:\projects\42r1-win\release\dll
Salah,
I would suggest you change to something like:
HDF4_LIB = /LIBPATH:$(HDF4_DIR)\release\dll Ws2_32.lib
It seems the NCSA has changed the layout of their distributed
binaries.
> Also what is Ws2_32.! lib i have nothing like this in the HDF
> distribution folder.
It is a Microsoft library. I can't recall what it does, though you
could check in google.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
Yahoo! Mail
Use Photomail to share photos without annoying attachments.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060309/5e2e4229/attachment.html
