[Gdal-dev] Visual Studio Project Files
Mateusz Loskot
mateusz at loskot.net
Tue Sep 19 13:36:45 EDT 2006
Simon Perkins wrote:
> On Wed, 13 Sep 2006 19:18:36 +0100, "Roger James"
>> Both Ben Discoe and I have done work on this. This has been
>> mentioned on this list occasionally in the past.
>> Ben's files are available for download the "Virtual Terrain
>> Project" site. http://vterrain.org/dist/gdal132_vc71.zip
>> I have some slightly updated versions of these files that you are
>> welcome to have if you want them.
>> I am not sure how many people are using VS 2005 yet. But VC7.1
>> (2003) is probably a good starting format.
> I have to say that I'm personally really only interested in the VS
> 2005 project files.
Simon,
Visual Studio 2002/2003 projects can be easily imported and
converted to VS 2005.
> VS 2005 also seems to be the point at which nmake starts to break
> down due to manifest issues and so forth.
No, that's not true.
As I wrote in my previous response, you can easily embed manifest when
building with nmake:
http://msdn2.microsoft.com/en-us/library/ms235591.aspx
nmake is a very important and widely used tool, so you can safely expect
that it will be supported by new release of VS in future.
> One idea is to have both 2003 and 2005 project files within the GDAL
> source tree, e.g. in gdal/visual_studio/2003 and gdal/visual_studio/2005.
Since, GDAL uses Visual C++ compiler, I'd vote on following proposal,
differentiating compiler versions and with short dir names :-)
<gdal>\msvc70 - VC++ 2002
<gdal>\msvc71 - VC++ 2003
<gdal>\msvc80 - VC++ 2005
> An objection might be that this might pose
> issues with keeping both sets of build files up to date, but if there
> are going to be project files for both 2003 and 2005 floating around
> anyway for different users, why not have them in the official source
> tree?
I think maintenance of these files will be a hassle.
May be it would be a good idea to write a script for adding new source
code files into project files automatically:
1. Scan subproject source tree
2. Find new file
3. Add it to the .vcproj (XML file in fact)
Cheers
Mateusz Loskot
http://mateusz.loskot.net
