[Gdal-dev] (no subject)
Moskovitz, Bob
Bob.Moskovitz at conservation.ca.gov
Tue Apr 24 17:21:49 EDT 2007
Hello All,
I have a quad map of California that is in a Shapefile. I converted this file into a KML file with ogr2ogr and displayed it in Google Earth. The quads are filled with white which blocks out the layers below. So after changing the style, I got a nice black grid and was able to view the other layers. What I want to do now is have the quad names display at the center of the quad. Reading the KML specs tells me that I have to add a POINT feature within the PLACEMARK tag. Rather then manually editing thousands of PLACEMARKs, I am hoping that there is an easier way to do it.
Does anybody have any suggestions? Maybe in the future there can be a creation option for the KML format that would solve this problem :)
Bob
CONFIDENTIALITY NOTICE: This communication is intended only for the use of the individual or entity to which it is addressed. This message contains information from the State of California, California Geological Survey, which may be privileged, confidential and exempt from disclosure under applicable law, including the Electronic Communications Privacy Act. If the reader of this communication is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070424/9e76e66c/attachment.html
