[Gdal-dev] --formats
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Wed Jan 24 10:26:22 EST 2007
Ah, sometimes open source development goes faster than the software upgrade
process in an organization :-). We are still running 1.3.2 ...
Thanks Frank.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Frank Warmerdam <warmerdam at pobox.com>
Naar: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
Cc: gdal-dev at lists.maptools.org
Onderwerp: Re: [Gdal-dev] --formats
Datum: 24/01/07 13:23
> Bart van den Eijnden (OSGIS) wrote:
> > Hi list,
> > using gdalinfo --formats, you get a title of the driver as well as
> > information on whether the driver is read-only, or read-write etc.
> > Using ogrinfo you don't get this information, just the driver code.
It would
> > be good to synchronize the two. Especially since there are drivers
which are
> > write-only in OGR.
> Bart,
> When I do "ogrinfo --formats" I get:
> warmerda at amd64[6]% ogrinfo --formats
> Supported Formats:
> -> "ESRI Shapefile" (read/write)
> -> "MapInfo File" (read/write)
> -> "UK .NTF" (readonly)
> -> "SDTS" (readonly)
> -> "TIGER" (read/write)
> -> "S57" (read/write)
> -> "DGN" (read/write)
> -> "VRT" (readonly)
> -> "AVCBin" (readonly)
> -> "REC" (readonly)
> -> "Memory" (read/write)
> -> "CSV" (read/write)
> -> "GML" (read/write)
> -> "KML" (read/write)
> -> "Interlis 1" (read/write)
> -> "Interlis 2" (read/write)
> -> "SQLite" (read/write)
> -> "PostgreSQL" (read/write)
> -> "MySQL" (read/write)
> I think this was added post GDAL 1.3.2. Was this inadequate in
> some fashion?
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
