[Gdal-dev] SetLocalCS() binding?
Simon Perkins
sy at perkins.net
Tue Mar 27 15:43:34 EDT 2007
Can someone clarify for me the purpose of the "local" coordinate system
which appears in the OGR API docs? I'm guessing this is for user-defined
special purpose projections?
In dealing with layers that don't have any georeferencing, I'm looking
for a convenient place to put a tag saying whether the coordinates in
the layer have the y-axis running up vs. down the screen. One
possibility I'm considering is to define a local coordinate system for
these layers and store the tag there.
Using the C# bindings, I thought I could just do something like:
OGR.SpatialReference ref = new OGR.SpatialReference("LOCALCS[\"MAP\"]")
and then call things like
ref.IsLocalCS()
However, that doesn't seem to work - the latter still returns false (or
rather 0 - but shouldn't we have bools here?).
I then turned to the SetLocalCS() method, but the bindings for that
don't seem to exist. Is adding them just a question of adding the
appropriate line to the SWIG ogr.i file, using the SetProjCS() entry as
a template? How do I then retrieve the name of the local coordinate
system? Using GetAttrValue("LOCALCS")?
While I'm here, what's the difference between OGR.SpatialReference and
OSR.SpatialReference? Why are there two such similar namespaces?
Cheers!
Simon
