[Gdal-dev] Coord ordering for given coord ref system?
Frank Warmerdam
warmerdam at pobox.com
Fri Nov 9 10:41:45 EST 2007
Baumann, Konstantin wrote:
> Hi all!
> It seems that there could be different axes ordering schemes based on
> the used coord ref system. For example, EPSG:31466 specifies a
> northing/easting ordering, whereas EPSG:31462 uses an easting/northing
> ordering (see for example
> http://www.bezreg-koeln.nrw.de/extra/33alkis/dokumente/2007-05-30_Revisionsliste_fuer_1-1.pdf,
> page 3, bottom right, in german).
> Could this ordering information be retrieved from OGRSpatialReference?
> How does GDAL/OGR handle such cases during vector data import?
Konstantin,
Currently OGR is "axis unaware" which does cause a number of problems. It
is something I would like to see fixed, but is a substantial effort and I
don't know when I will get to it. If someone else is willing to make a
substantial effort on this task, I would appreciate input into the approach
taken.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
