[gdal-dev] ogr_OCI plugin can't find OCI.dll
Lucena, Ivan ivan.lucena at pmldnet.com
Wed Apr 2 11:02:19 EDT 2008
Hi there,
I am getting a "...OCI.dll was not found..." message when trying to use
the OCI plugin.
That is what I did:
I downloaded the GDAL 1.5.0 binary distribution for win32 and the OCI
plugin:
gdalwin32exe150.zip
gdalwin32oci150.zip
And I extracted it to:
E:\gdalwin32-1.5\bin
E:\gdalwin32-1.5\bin\data
E:\gdalwin32-1.5\bin\gdalplugins
I reset all other GDAL related environment variables to:
set path=%path%;E:\gdalwin32-1.5\bin
set GDAL_DRIVER_PATH=E:\gdalwin32-1.5\bin\gdalplugins
set GDAL_DATA=E:\gdalwin32-1.5\bin\data
The OCI.dll is on the windows path. I can run executable from the the
same folder, like sqlplus.exe for example. BTW, the version I am using
is 10.2.0.1.0.
When I run gdalinfo I've got the windows dialog box error message
"...OCI.dll was not found..." and GDAL error report:
% ogrinfo
ERROR 1: Can't load requested DLL:
E:\gdalwin32-1.5\bin\gdalplugins\ogr_OCI.dll
193: %1 is not a valid Win32 application.
I can see on the Process Monitor that OCI.dll was found and successfully
loaded. So, I don't know that is happening.
Does anybody has a clue?
Thanks in advance,
Ivan
