[gdal-dev] ESRI file database
Clay, Bruce
bclay at ball.com
Thu Feb 7 11:43:33 EST 2008
I checked the supported format list and did not see ESRI file database.
Is a driver in the works or does some other existing driver work with
them such as the SDE driver?
Bruce
This message and any enclosures are intended only for the addressee. Please
notify the sender by email if you are not the intended recipient. If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful. Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080207/b6d5d96d/attachment.html
