[gdal-dev] ESRI file database
Frank Warmerdam
warmerdam at pobox.com
Thu Feb 7 11:59:59 EST 2008
Clay, Bruce wrote:
> I checked the supported format list and did not see ESRI file database.
> Is a driver in the works or does some other existing driver work with
> them such as the SDE driver?
Bruce,
There is no driver in the works (that I know of). I don't know if it can
be used through the SDE driver. I got the impression once from an ESRI person
that there is a higher level API we should have been using if we wanted one
way to use all ESRI feature databases.
I understand the format is supposed to be "open" but that it wasn't clear how
this would be accomplished a year ago. Perhaps someone could ask if it is now
clear, and how it is accomplished so we can write a driver.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
