[gdal-dev] Does CCITTFax-Compression of GeoTiffs work for you?
Frank Warmerdam
warmerdam at pobox.com
Sun Jan 13 12:39:25 EST 2008
Tom Kazimiers wrote:
> Ivan,
> thanks for your answer. I do not think that IrfanView writes out of
> standard CCITT - bu anyway I tryed with gdal_translate.
> Maybe I interpret this information wrong, but "gdal_translate --format
> GTiff" gives the following output:
> Format Details:
> Short Name: GTiff
> Long Name: GeoTIFF
> Extension: tif
> Mime Type: image/tiff
> Help Topic: frmt_gtiff.html
> Supports: Create() - Create writeable dataset.
> Supports: CreateCopy() - Create dataset by copying another.
> Creation Datatypes: Byte UInt16 Int16 UInt32 Int32 Float32 Float64
> CInt16 CInt32 CFloa
> <CreationOptionList>
> <Option name="COMPRESS" type="string-select">
> <Value>NONE</Value>
> <Value>LZW</Value>
> <Value>PACKBITS</Value>
> <Value>JPEG</Value>
> <Value>DEFLATE</Value>
> </Option>
Tom,
These are creation options and do not indicate what compression types
are available when reading TIFF files. In 1.4.3 the FAX compression types
were not supported by GDAL when creating a TIFF file but should be supported
when reading a file.
I don't know why you are having problems. I would suggest you try reading
the file with a standard build of GDAL (for instance the FWTools build)
and verify that it works at which point you can hopefully isolate your
issue to being WinCE related.
If it is a WinCE specific problem you may need to solve it yourself or
discuss it with Mateusz Loskot. But Mateusz is mostly unavailable for
several weeks.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
