[gdal-dev] does gdal support radarsat-2 NITF format ?
Tue Nov 25 14:38:08 EST 2008
Gong, Shawn (Contractor) wrote:
> Hi list,
> Does gdal (1.5.3 or 1.6 beta) support radarsat-2 SLC NITF format?  I
> believe it is a 64-bit complex NITF.  if so, should I open the
> product.xml or the imagery_HH.ntf?
Shawn,
As mentioned, I don't think the Radarsat 2 product.xml driver supports
NITF though it might by virtue of not really paying attention to the
image format (just using GDAL for it).
However, I believe the NITF driver does not currently support 64bit
complex NITF files.  So a little work may be required in that driver
to get this working.  I don't suppose there are sample files that
can be made available for development purposes?
Best regards,
