[gdal-dev] gdaltransform results differs from qgis
Markus Neteler
neteler at osgeo.org
Mon Sep 15 07:52:54 EDT 2008
On Mon, Sep 15, 2008 at 12:43 PM, Antonio Parrotta
<antonioparrotta at gmail.com> wrote:
> Hi,
> I solved, it was because epsg:3003 was missing in epsg file and proj env
> variable were not set. I have add
> +proj=tmerc +lat_0=0 +lon_0=9 +k=0.9996 +x_0=1500000 +y_0=0 +ellps=intl
> +units=m +no_defs
> in epsg file
> now I have same result as you.
> Thanks a lot for the helping me!
.. you are welcome but I would double check the installation if things like this
are missing. You are likely to run into new troubles soon if the epsg file is
broken.
Best
Markus
