[gdal-dev] problem with 5D variables in NetCDF
Michael Sumner mdsumner at utas.edu.au
Tue Sep 23 16:26:59 EDT 2008
Hello,
No objections to using the file - I manufactured it to test the higher
dimension cases.
Cheers, Mike
Frank Warmerdam wrote:
> Michael Sumner wrote:
>> Hello,
>> The 5D dataset in this NetCDF file causes an error on Windows but not
>> on Linux.
>> http://staff.acecrc.org.au/~mdsumner/gdal/foo.nc
>> The Windows FWTools is recent, and the Linux version is old:
>> Linux: GDAL 1.5dev, FWTools 1.3.2, released 2007/06/01
>> Windows: GDAL 1.6.0dev, FWTools 2.2.6, released 2008/08/22
>> Is this a known problem? Variables of 2D, 3D and 4D all seem fine on
>> Windows even
>> when in a file containing a 5D variable.
>> I've put details below for (1) the file, (2) the SDS on Linux, (3)
>> the SDS on Windows.
> Mike,
> I have confirmed this problem and discovered that gdalinfo on the
> same thing reports problems on linux if run under valgrind (but
> happened not to crash).  So the bug is not actually new.  I have
> filed:
>   http://trac.osgeo.org/gdal/ticket/2582
> on the issue, and am committing a fix in subversion now.
> Thanks for the bug report.
> Do you have any objection to foo.nc being incorporated into the GDAL test
> suite as public domain data?
> Best regards,
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.169 / Virus Database: 270.7.1/1686 - Release Date: 9/23/2008 7:38 AM
