[gdal-dev] KML output fields
Clay, Bruce
bclay at ball.com
Fri Sep 26 13:52:56 EDT 2008
When I use ogr2ogr to convert a shapefile to KML there are no "Name" or
"Description" fields in the output and all attributes are lined up.
When I try to create a KML file from my code and populate the data both
"Name" and "Description" fields are included in the output.
I have tried not a variety of things in the call to KML's
CreateDataSource
Not setting any options (i.e. passing a NULL)
Setting both to empty strings
CSLSetNameValue( ogrOptions, "NameField", "");
CSLSetNameValue( ogrOptions, "DescriptionField", "");
Setting both to "None"
CSLSetNameValue( ogrOptions, "NameField", "None");
CSLSetNameValue( ogrOptions, "DescriptionField", "None");
None of the above will remove the 2 fields from the output KML as a
result all real attribute values are sifted up 2 places.
I looked in the ogr2ogr.cpp and I do not see any parameters getting
passed into the call.
Does anyone have any idea what might be causing this?
Bruce
This message and any enclosures are intended only for the addressee. Please
notify the sender by email if you are not the intended recipient. If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful. Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080926/4d008841/attachment.html
