[gdal-dev] strange path handling of ogr2ogr in append mode
Matthieu Rigal
rigal at rapideye.de
Wed Aug 12 08:53:23 EDT 2009
Hi folks,
Sorry to bother you with a problem occurring on an obsolete version, I will
find a work-around for me, but I wanted to tell you -after making sure this
was not reported before-, that on my 1.6.1 installation under Linux,
ogr2ogr -update -append
is making strange errors :
It interpretes the paths in a strange way:
ogr2ogr -update -append merge.shp fileone.shp -nln second
ERROR 1: Failed to create file .shp file.
ERROR 4: Failed to open Shapefile `merge.shp/second.shp'.
AND
ERROR 4: Failed to open Shapefile `merge.shp/fileone.shp'.
If it was resolved, forget it, if I am the only one, forget it maybe also...
but this is strange...
Regards,
Matthieu
Matthieu Rigal
Product Development
RapidEye AG Tel: +49-(0)3381-89 04 331
Molkenmarkt 30 Fax: +49-(0)3381-89 04 101
14776 Brandenburg/Havel
Germany http://www.rapideye.de
RapidEye AG
Molkenmarkt 30
14776 Brandenburg an der Havel
Germany
Follow us on Twitter! www.twitter.com/rapideye_ag
Head Office/Sitz der Gesellschaft: Brandenburg an der Havel
Management Board/Vorstand: Wolfgang G. Biedermann
Chairman of Supervisory Board/Vorsitzender des Aufsichtsrates: Axel Schmalz
Commercial Register/Handelsregister Potsdam HRB 17 796
Tax Number/Steuernummer: 048/100/00053
VAT-Ident-Number/Ust.-ID: DE 199331235
DIN EN ISO 9001 certified
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte
Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den
Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
The information in this e-mail is intended for the named recipients
only. It may contain privileged and confidential information. If you
have received this communication in error, any use, copying or
dissemination of its contents is strictly prohibited. Please erase all
copies of the message along with any included attachments and notify
RapidEye AG or the sender immediately by telephone at the number
indicated on this page.
