[gdal-dev] GDAL 1.6.1 RC2 Released
Even Rouault even.rouault at mines-paris.org
Tue May 12 14:46:25 EDT 2009
William,
I've verified that one of the updates of internal libtiff from CVS head
includes two missing byte-swapping (see
http://trac.osgeo.org/gdal/changeset/16836#file5 and
http://bugzilla.maptools.org/show_bug.cgi?id=1924) that explain the error you
get with an older libtiff 4.0beta.
I'm not very surprised that upgrading to the new libtiff version is necessary
for the current geotiff driver, as it just worked by chance with the
combination of geotiff driver & internal libtiff of 1.6.0, so the conclusion
is : just upgrade your libtiff to CVS head or use internal libtiff.
About gdalbuildvrt, some people apparently wanted it badly in 1.6.1, so here
it is ;-) The related man and HTML pages for the utility will also be
generated in the build process (if that's what you mean by "a new doc package
with a help file for this").
Best regards,
Even
Le Tuesday 12 May 2009 06:38:51 William Kyngesburye, vous avez écrit :
> Same external libtiff 4 beta and internal geotiff as I've always
> used.  Actually newer, beta 3, than I used in GDAL 1.6.0 (beta 2).
> Maybe something important has been updated in libtiff since beta 3?
> I see that there are a lot of very recent changes in the internal
> libtiff, maybe they are related to the many changes in the gtiff
> driver.  If so, it would be nice to have a new libtiff beta.
> On May 11, 2009, at 11:08 PM, Ivan wrote:
> > William,
> > I might be wrong but I think that this TIFFReadDirectory error is
> > because you need to use the GDAL internal libtiff/geotiff libraries
> > as in Linux:
> > ./configure --with-libtiff=internal --with-geotiff=internal
> > Regards,
> > Ivan
> > William Kyngesburye wrote:
> >> Just got done testing RC1... Autotests all OK on OSX except for a
> >> new failure:
> >>  TEST: tiff_ovr_10: tiff_ovr_10_interverted ... ERROR 1:
> >> TIFFFetchDirectory:tmp/ovr10.tif: Can not read TIFF directory count
> >> ERROR 1: TIFFReadDirectory:Failed to read directory at offset
> >> 1276248064
> >> fail
> >>    Failed to open copy of test dataset.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "This is a question about the past, is it? ... How can I tell that the
> past isn't a fiction designed to account for the discrepancy between
> my immediate physical sensations and my state of mind?"
> - The Ruler of the Universe
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
