[Gdal-dev] GDAL "ignores" explicitly defined nodata value
orbiter_postmuch
dan0225 at sbcglobal.net
Sun Sep 27 06:15:46 EDT 2009
NOTE-Since people' responses come through the mailing list only, expect a
line of new topics in a row by me to flood (by "flood" I mean 4 topics in a
row by the same author) the forum.
After successfully building the .vrt and translating it to .img, I opened
the file and found that the white (nodata) values were copied over valid
data. I then tried this:
The nodata value in the map was specified as 253 in the official PDF. Still,
no luck.
Here is an example of the tiling:
http://n2.nabble.com/file/n3720196/tiling.jpg
Also, when I checked the .vrt, the size was reported as, '<VRTDataset
rasterXSize="91727" rasterYSize="45855">'
Now, a 500 meter/px image would be 86400x43200 pixels. A 250m image would be
172800x86400 pixels. The landmask was 231.7m. The reported size was half the
resolution of the map!
View this message in context: http://n2.nabble.com/GDAL-ignores-explicitly-defined-nodata-value-tp3720196p3720196.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
