[gdal-dev] Help with coordinate transformations in OGR
Alexandre Gacon alexandre.gacon+gdal at gmail.com
Mon Sep 28 09:58:50 EDT 2009
Thanks for the great tool you give us with the OGR library.
I actually meet some problems with a specific coordinate transformation : I
need to transform coordinates from the NTF Lambert II Etendu system
(EPSG:27572) to WGS84 (EPSG:4326).
When I 'simply' transform a shapefile with ogr2ogr in the WGS84 system, I
get shifted geometries, compared to trusted sources. After some inquiry, it
appears that an additionnal transformation is needed (a geocentric
translation).
Is there a way to handle this transformation with the OGR API ?
The EPSG registry contains a coordinate transformation (EPSG:15939) which
seems to handle my problem : is-there any mean to use it with OGR ?
Best Regards,
Alexandre Gacon
Sent from Paris, France
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090928/a13e90c8/attachment.html
