[gdal-dev] Problem converting .gml to shapefile
Chaitanya kumar CH chaitanya.ch at gmail.com
Mon Sep 28 23:16:03 EDT 2009
Adrian,
May be the problem is with xerces. OGR's GML driver has some problems
with the latest xerces3 xml parser. It works perfectly with xerces
2.8, however. I'm looking into the xerces 3 support now.
On Mon, Sep 28, 2009 at 10:42 PM, Chaitanya kumar CH
<chaitanya.ch at gmail.com> wrote:
> Adrian,
> I was not able to reproduce the issue. I am attaching the shapefile I
> got with ogr2ogr, which seems to be correct.
> It may help if you test your gml file with ogrinfo with the options
> -al and -so. Check for consistent feature count.
Best regards,
Chaitanya kumar CH.
