[gdal-dev] swig generated files for Perl bindings removed from
repository
Ari Jolma
ari.jolma at gmail.com
Thu Aug 19 03:26:00 EDT 2010
Folks,
This was discussed a while ago[1] and while there was no general
conclusion, I believe there is no requirement for the Perl bindings to
keep the generated files in the repository. In fact, I recommend that
the Perl bindings are regenerated every time they are built. The only
exception is if you are using an official release (either of GDAL itself
or Geo::GDAL - but see below), which is guaranteed to have updated
bindings built in the release process.
Note that "make generate" in swig/perl is not guaranteed to build
updated bindings since the dependencies are not complete, the old ones
need to be deleted first with "rm *wrap*".
Perl bindings are not so picky on swig version. swig version in latest
Ubuntu is 1.3.40 and it is ok, but also 2.0.0 seem to work ok (I just
tested). swig for windows binaries also have worked without problems.
I have been negligent at updating the Perl bindings as a CPAN module. A
CPAN package (currently Geo-GDAL-0.23.tar.gz) can be generated from the
bindings by "make dist". The package includes the swig generated
bindings. Testing now it seems that building the package out of GDAL
distribution fails due to (at least) include file swq.h not being found.
This is a known bug[2], not related to the Perl bindings.
Ari
[1] http://lists.osgeo.org/pipermail/gdal-dev/2009-May/020665.html
[2] http://trac.osgeo.org/gdal/ticket/3468
