[gdal-dev] gdal_translate not working/ windows 7 64bit?
Tamas Szekeres szekerest at gmail.com
Fri Mar 5 16:32:25 EST 2010
Hi Chris,
While I'm no aware of any specific issues related to Win7 if you provide
some test data I could try your command on my Win7 x64. So as to make sure
about the problem you might also want to test with the binaries available at
http://vbkto.dyndns.org/sdk/  (Run sdkshell.bat for the command prompt).
Best regards,
Tamas
2010/3/5 ggp08ctl <ggp08ctl at sheffield.ac.uk>
> Hi all,
> I have used gdal before (very briefly) to translate gebco bathemetry data
> from the netcdf file it comes as, into a tif format that I can use/ further
> convert in esri arcgis software. When I used gdal before (on another
> system)
> I used the osgeo4w windows version on 64bit vista, and simply typed in the
> command 'gdal_translate -a_srs EPSG:4326 filename.nc' at the command
> prompt.
> This worked well. I now need to repeat the process, this time using osgeo4w
> on 64bit windows 7.
> The problem I am having is that this no longer seems to work. I go to the
> osgeo4w command prompt, type in the above with the appropriate file name
> and
> nothing happens. I just get the standard dos message regarding the usage of
> the tool. Gdalinfo works ok. I do not believe that I am typing anything
> incorrectly. Does anyone know if the issue is associated with my change of
> OS? Should there be entries for osgeo4w or gdal in environment variables,
> because there doesn't seem to be any at present. Any suggestions
> appreciated.
> Regards,
> Chris
> http://n2.nabble.com/gdal-translate-not-working-windows-7-64bit-tp4683419p4683419.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100305/9a805b5f/attachment-0001.html
